A rattle on cold start, a timing fault code or a warning light can all point to a stretched timing chain. On many Land Rover and Range Rover engines, a chain that’s left too long can jump or snap, and the damage that follows can mean a replacement engine. We check, advise and replace timing chains before it gets to that.
PHOTO 9
Timing chain job: front of engine opened up
Signs of a worn timing chain
- A rattle for a few seconds after a cold start
- Engine management light with timing or camshaft correlation fault codes
- Rough running or loss of power
How we deal with it
We start with diagnostics, reading the timing correlation data to see how far the chain has stretched, and if needed we inspect it. If it needs doing, we replace the chains, guides and tensioners together and give you a price first. We work on the timing systems used across the range, including the Ingenium engines in the newer Discovery, Discovery Sport, Defender, Range Rover Evoque and Velar.
Warranty
Parts and labour carry up to two years’ warranty, the same as a main dealer.
Book a timing chain check
Call 01886 880905, message us on WhatsApp, or send a booking request and we’ll confirm a time.
