Warning lights, limp mode, or a fault another garage couldn’t find? Modern Land Rovers have dozens of control modules, and a cheap code reader only sees a fraction of them. We use Autologic dealer-level diagnostics for most work, and Land Rover’s own software for specialist programming and configuration. Between them they read every system on your vehicle, so we fix the fault rather than guess at it.
PHOTO 8
Diagnostic laptop plugged into a Land Rover, technician at work
Faults we trace
- Engine management lights, loss of power and limp mode
- Electrical faults, flat batteries and things that work one day but not the next
- ABS, traction control and Terrain Response warnings
- Gearbox and transfer box faults
- Air suspension warnings
- DPF and EGR warnings on diesel models
What a diagnostic check involves
We read the fault codes from every module, look at live data and, where it’s needed, test the components and wiring involved. A fault code tells you where to start looking, not what to replace, so we test before recommending any parts. You get a clear explanation of what we found and a price for the repair before any work goes ahead.
Common questions
The warning light has gone out. Is a check still worth it?
Usually, yes. Most faults leave a stored code after the light goes out, and an early fault is normally cheaper to fix than one that’s been left to come back.
What if the fault comes and goes?
Intermittent faults are the hardest kind. We check the stored fault history and the data recorded when the fault happened, and we may ask to keep the vehicle longer to reproduce it.
Do you do programming and software updates?
Yes. We use Land Rover’s own software for module programming, configuration and updates, and Autologic for most diagnostic work.
Related: air suspension repair, DPF and EGR repair, timing chains and gearbox and transfer box servicing. We also diagnose Jaguars and cars and vans of every make.
Book a diagnostic check
Call 01886 880905, message us on WhatsApp, or send a booking request and we’ll confirm a time.
